A-arm Bushings
Featured Build Threads
bruker
Western, Ohio
The A-arm bushings on my Ranger are creaking and groaning quite a bit. Aside from changing them out is there any kind of lube I can use that will quite them down but not harm the rubber?
Maybe white lithium spray grease.
are you sure they aren't worn to the point of allowing metal-to-metal contact someplace?
try lubing the ball joints & tie rod ends.
So change 'em out! If I can do it on my 2002 4WD Ranger, you can as well.
Featured Ranger Based Vehicle
