99 xl speaker radio help
AdamKirk
5+ Year Member
My 1999 xl standard cab has factory am/fm radio with speakers in the door. My radio does not have a fade from front to rear feature...nor a left/right balance.
I desire to replace with a factory am/fm cassette deck.
Behind my seats are speaker grills, but no speakers.
Any advise will be helpful.
Are there wires in the rear speaker housing to connect rear speakers?
Will a factory am/fm cassette connect with my wiring harness?
Thanks in advance.
Adam
Raleigh NC
Welcome to TRS!!!!!
Bought new or used?
Most likely was a special order fleet truck. Probably does not have the wires in the rear speaker locations but then again it might.
Best thing to do is check out Crutchfield.
http://www.crutchfield.com/Car/outfitmycar/car.aspx
The site can help with what fits your truck and gives you a lot of free stuff if you buy from them, also unlimited lifetime tech support.
I have been a loyal customer for over 30 years.
I second the motion for Crutchfield. I have a co-worker who has used them heavily over the years. He says they often include installation stuff like wiring adapters, brackets, etc. for free when you buy a stereo from them.
Pop the speaker grills off and see if the wires are there. There's a good chance that they are tucked in there as part of standard truck wiring. Even if they aren't, it's a small, standard cab truck - won't take much wire. I would recommend running both conductors to each speaker. Don't use the truck body as a ground (return path).
