Chuckyc19977
So I got a 0171 code and went got new 02 sensors put them on fired the truck up check engine light still on while I was under there noticed didnt have a cat yup went and got q cat put that on there will start but I have to floor it ok maybe something with the cat took cat back off put the pipe that was in it back in it its still doing same thing. I have to hold my foot to the floor it runs like your flooring it then it sounds like you got no gas then it runs like your flooring it again just flutters back and forth like that. Any help would be great oh and I did check the inertia switch and the red button was down even pushed on it to make sure. As right now im thinking fuel pump fuel pressure regulator or possibly a fuel filter? Any other ideas and can these parts be cleaned like maybe I sucked something up in them
