It is a Public Forum, so there will be people that abuse others, unfortunately that is unavoidable in the short term, but consistent abusers are usually banned.
A monkey can write a Shakespeare play as well, and a monkey is smarter than the person that called you a monkey, so.......grain of salt
Timing belt remove and replace work is by no means easy, I think people might mean there is a lot of boring wrench work to get to the part that requires some skill and specific knowledge, and then more boring wrench work to put it back together.
So with the 131 tooth belt installed do the timing marks line back up after two rotations of the Crank shaft?
They should
I can't see the number of teeth on the belt making any difference at all, the number of teeth on the cam, crank and oil pump gears are the only thing that matters and you haven't changed those.
They should
