Curious Hound
I know a guy with a website
TRS Event Staff
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
GMRS Radio License
- Feb 7, 2016
- Age
- 62
- Wellford, SC
- State - Country
- SC - USA
- Other
- 2002 F250, 2022 KLR 650
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 3.0L
- Total Lift
- 6"
- Tire Size
- 35"
- My credo
Ok. So the answer is; if no broken bolts, it doesn't. Or, if it hasn't been stuck together for 30 years. I don't like the idea of sliding the timing cover off in a sgearing movement against that gasket.FIFY
When I did my FEAD swap in 2012
When I did my head swap in 2023 (and broke a bolt removing the PS bracket)
When I pulled my brackets in the JY I had that Explorer stripped down to the timing cover. I was looking right at it. Had my brackets and stuff in one pile and the radiator/condenser and everything else in another pile, I had gone to town stripping this thing. It had one broken bolt in the water pump so the timing cover had to slide straight off. Not possible without shearing the oil pan gasket in half (cover would probably break first) IIRC I made two trips up there fighting with the thing and gave up and ordered a new cover.
Without a broken bolt when you remove the dampener you have enough slop in the front seal you can easily remove the cover. If you notice my 1yo one piece gasket did stick to the cover and one end tore off each time but a dab of silicone and it is still bone dry.
