91 Ford Ranger Air Intake Issu
muwaha
Forum Member
Hazel Green, AL
Hey All,
I hope I'm posting in the right place.
I have a 1991 Ford Ranger V6 3.0L.
The air intake hose is bad causing additional air to get into the hose itself that sits between the MAF and the butterfly on the engine.
I cannot find a replacement online or at my local junkyard.
I've thought about going aftermarket but it seems that the metal piece on the engine that goes to the butterfly is too small for any aftermarket solution to work so I'm thinking I'd need to fabricate an adapter.
I wanted to see if anyone else ran into this issue and what was the solution?
Gorilla tape? It's pretty sticky, and black.
I did that a few years ago and though that helps the middle portion so to speak, I guess the heat of the engine made it lose it's adhesive.
Even though I have the clamps on the air filter housing and the butterfly, air is still being sucked in, no matter how tight I make those hose clamps.
I can put my finger near the ends of the hose where it connects to the throttle body/butterfly and the air filter housing and feel additional air being sucked in.
My 94 needs a new duct too. I've patched it up with ultrablack. I found an exact replacement on Ebay.
I'm having vacuum problems but I don't think it's the duct. How long should vacuum stay up after cutting the engine off. Mine drops to 0 almost immediately. I knew I was having vacuum problems cause my brake booster check valve was acting like its defective. I bought a new one but no change. Maybe the grommet. Gonna ultrablack that next. Vacuum is running at the bottom of the green on a 300k mile 3.0 engine at idle. Thanks all.
When you shut an engine OFF...
Vacuum instantly drops to ZERO.
I ordered aluminum intake tubing and silicone elbows and couplings from ebay or Amazon or somewhere and built my own.
you should not put silicone or anything in regards to sealing your intake tubes you dont want in your valves. its soft so usually it just gets sent to the converter.
Ultrablack solidifies pretty hard overnight. Curious hound, got any pictures of your mod.
Catalytic converter is not a problem. It had become a dogalytic converter because it was dogging the engine down so I converted it to a nonalytic converter.
I used a reducing coupler at the throttle body. Everything else is 3" aluminum tubing wuth various elbows and couplers.
used the original MAF so it matches my engine and ecu
Since I did a snorkel setup, i upgraded to the riund style air filter housing. I think it's from a newer 4.0l. (Junk yard parts) It took some fiddl8ng to get my original MAF mated ro the newer air filter housing.
I have to wonder if that made any difference in flow to the 3.0...
I’m sure I reduced the resistance to flow. The original piping was very restrictive, including the piece between the core support and original airbox.
Did it increase horsepower? I have no clue. Maybe by 1/2 hp. Not significant.
So, Muhawa, did you find your hose?
My hose came in 2 days. Ordered it off of Ebay but came thru Amazon. (Go figure.)
Perfect fit. Made in China. Clamps included.
Seemed to solve the idling issue. Trying to get all my maintenance issues done before winter.
Nothing worse that working on your truck in the cold or rain.
Do you have an Ebay or Amazon account? You need one!
  • 91 Ford Ranger Air Intake Issu
