Lots of progress today! Love having Mondays off.....
I got the rear wheelwells all cleaned up and detailed {the white overspray was really buggin me} and battery is mounted in the bed and truck now has power. So far havent found anything that doesnt work correctly.
I got the T5 installed today and only had to make a small mod to the crossmember to get everything to bolt up.
Will have to make new hole in floor for the shifter.
I was really hating the red MSD wires and coil so I replaced them with some black Ford Motorsport wires and blacked out the MSD coil. I pulled the heaterbox back off to make more clearance for my downpipe and laid some reflective heat tape on firewall near the exhaust.
Got all the power brake crap off and almost finished the manual swap tonite. I found out the TurboCoupe clutch master wont bolt to the Ranger firewall so I need to go buy a Ranger master tomorrow then I can finish plumbing the clutch.
Got the intake back on and have one more weld to finish and the front mount to throttlebody plumbing will be finished as well.
My new Stinger Performance PIMP ecm should be here shortly then I can start wiring the motor.
And it looks like Im in need of a new driveshaft since the original is about 10" to short now. I have 60" between the axle flange and the tailshaft.
	 Welcome Visitor! Please take a few seconds and
