clayborne
- Dec 21, 2010
- Automatic
I have a 1988 bronco II 4x4 and it's A4ld has been given me nothing but problems, so I have been considering installing a 5 speed. I looked long and hard to find a 4x4 one but have had no luck. I found a 2wd M50d at the local jy from a 98 ford ranger and was curious if this could be used if i grabbed the drive shaft also. I know from research that this is not a direct bolt on due to the fact that the transfer case will not be used. I know this is not an ideal solution but I have been asking myself if it is better to have a 4wd lawn ornament or a 2wd daily driver.
