Diggerauditor
OKay, reading some forum threads I realized I screwed up my idle screw, which is not really an idle screw but a TPS adjustment...sigh.
My truck has 172k on it and has run fine and still does. I rebuilt the top end about 30k ago, cracked head, but everything is fine. My son has been driving during the summer and came over saying that the idle was jacked up. The idle was in fact wacky so the first thing I did was remove spout connector and check timing, it was fine. Then I started moving the idle screw and thats where it all started.
My guess is the IAC was bad, and or the TPS. I adjusted the idle screw, and then adjusted the TPS and unplugged battery. No luck. Had to drill out TPS mounting holes to get it to adjust. This morning I replaced the IAC with one from my 91 Mustang 5.0, uses the same exact one, and the idle is still all over the place. I need help setting the idle/TPS screw back to where it should be and then diagnosing the IAC or TPS. Im leaning toward TPS since my mustang always drives great.
Any help would be appreciated. Thank you in advance.
