Jaycejohnson1998
Howdy, first time posting here, I’m Jayce.
I daily a 1986 Eddie Bauer bronco 2 with 85k miles and I love it but this 2.9 is perplexing me.
The engine starts only if you floor it as you turn the key and quickly let off the throttle. I’ve replaced the computer as my stock one wasn’t outputting trouble codes even after recapping the board. $108 dollars later it starts betterish and I busted my test light walking to the truck to check codes.
It starts much better when cold but even then you still have to floor it and let off. It runs super rich for around 10 seconds then smooths out but will not idle down lower than 1100rpm even with the screw backed all the way out. I’ve read and read through the many 2.9 threads on here and I can’t find anyone with the exact same set of issues. I’m almost scared to pick up a new test light and find out that the harness isn’t any good when it never even blinks haha. I’d appreciate it if anyone who had experienced the same stuff could lend a guiding hand,
Thanks!
Thanks!
