85_Ranger4x4
Wallers in rivers
💻 TRS Socials
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
- 5.0L
- Manual
I'm running the HEI with the duraspark distributor and TFI coil.
I know on the 2.8, but in 5 years (knock on wood) I've had no trouble with it.
I've debated EFI, but I'll be hard pressed to abandon the mechanical fuel pump because it just simply works.
My only intent for the EFI would be to increase MPG, but I can live with crap mileage as long as it is dependable, which so far it has proven to be.
Really for the last 15 years I have been happy with what I have. I have driven it farther from home every year beginning in 2019 than I have any of my daily drivers. Mileage is decent, close to 20mpg which loaded heavy for camping/offroading is far from terrible.
Elevation changes and off camber were the main drivers that inspired me to go to EFI. It will also bump the idle for the A/C and control the fuel pump and efans.
I don't have room for a mechanical pump, my current timing cover doesn't have provisions for one and if my A/C compressor wasn't in the way my steering box is also in the way lol.
My big hangup initially with having the EFI control the ignition was I didn't want to get stuck trying to track down a weird brand X distributor cap in 10 years. Then I discovered I could lock up the advance on the dizzy I have and still be able to use DS caps/rotors.
Then thinking I was gtg on ignition I thought I would just get the EFI working first, work any bugs out of that and then convert the ignition over.
Right now after researching it more and more... I think I am just going to do it all at once and be done with it. Its like four more wires and I already have a nearly new Motorcraft TFI coil.
Having the ignition controlled by the computer is the best so the computer isn't always trying to guess what the vacuum advance and whatever is going to be doing next.
