84 bronco II 2.8 rattle noise lower engine
Featured Build Threads
mightysonofa
10+ Year Member
mars
I have a 84 b2 2.8L with 119,000 0n it . out of the blue it started to make a strange rattle noise heard either at cold start and then after warm up at idle , it sounds like very loose lifters it does not hesitate or lack power nor does it have a miss ,I have always changed the oil and other than the rattle noise it runs and drives fine .If I go to start it and it doesn't start right away as the engine is still spinning a bit you can hear it the best . it almost sound like something in the bottom of the engine not a rod but a loud rattle. Like something rolling around in there I've checked the exhaust it is all brand new from the y pipe back even the cat is new .if it is making the noise as soon as I give it a bit of gas it goes away .I took it to a shop they said it has low oil pressure . If so do I need a new engine or should I pull the engine and replace the pump then adjust he valves and see what's up after that .I haven't had much experience with these old engines . one guy told me it sounds like the timing gear has broken off but I don't hear the noise under the hood just under the truck in the lower engine . Any Ideas?
I seriously doubt it's a broken timing gear. You wouldn't likely be running if it were.
If your oil pressure is low, it could be the pump. But I suppose it could also just be a bad pressure sender.
Bad oil pump wouldn't necessarily mean a new engine, but that would depend on how long you've been running the engine with a bad pump (assuming that's the problem).
You don't need to pull the engine to get to the pump. Unbolt the transmission from the cross member; remove the distributor (and carb if it makes it easier); remove the engine mount nuts. Then use a jack to lift the engine enough to place wooden blocks under the mounts...cut four lengths of 2x4s, enough to place two on each side under the mounts. Then slowly lower the engine onto the blocks. This should give you enough clearance to unbolt, lower, and remove the oil pan (after you drain the oil of course). This should also give you enough clearance to remove the oil pump (replace it with new; do not buy a rebuild kit). Check and replace (if necessary) the oil pump shaft. Gaskets will come with the new oil pump.
Again, this is assuming the oil pump is bad, but didn't cause any damage to the bearings...which you won't know unless you pull the engine and tear it down, or unless you find bearing fragments in the oil pan when you check it.
EDIT: You shouldn't have to mess with adjusting the valve lashings. Once they're set, they're pretty much set, and adjusting them can be a tricky PITA.
Event Coverage
Featured Ranger Based Vehicle
