6 Inch Lift Questions
Which 6 inch lift kit is better?
  • Total voters
  • This poll will close: .
After talking to the shop so more today they think the BDS kit is the way to go. Main reason is they say the steel BDS is better and a thicker gauge. They also like that the front diff is more protected via its placement a little higher in the lift. Any thoughts on these points?
BDS has two 6" kits. This is the pricier one:
I think this is the kit I want.
Also, they are quoting 5000 installed. BDS kit with Fox 2.5s
Also compare anything you can find with ride quality with springs/struts between the two. If it has no articulation and rides like a lumber wagon you ain't gonna like it.
The thicker gauge metal is a selling point.
The differential being higher better because it sits higher, depends on what the joint angles are on the CV shafts. Too sharp of an angle will decrease CV joint life.
85_Ranger4x4 has a point on researching what the ride will be like with these kits.
Admittedly I have not felt what the Fox 2.5’s feel like. I currently have Eibach ProTruck 2.0’s that are completely preloaded to achieve my current ride height. The loaded Eibach’s are a little firm.
When I was talking to the shop that put my level on I told the guy I was looking at Truxxx and BDS and he said BDS was a good kit.
I went with the Truxxx for other reasons, I'd had their lift kit on my old Sport Trac and was happy with it, plus Truxxx had a 1.5" while BDS was 2" and I have garage clearance issues. The BDS kits seem to be very complete and well-made.
I clicked on this thread on the sidebar thinking it was gonna be for a 6" TTB lift lol
Having a good amount of hands-on experience with BDS & Rough Country kits for the Toyota Tacoma, I still should be able to offer a good bit of useful info though.
BDS definitely is the kit with better build quality, although RC is not what I would call "junk" either (not like their TTB kits are), and is less $$$.
BDS has the Fox shock option, which is very hard (if not impossible) to beat. RC has their Vertex shocks, which also are quite good, but not quite on the same level as Fox (they probably don't have as good parts availability for rebuilding/revalving them either).
Both kits crossmembers are made from ¼" thick welded plate, however the BDS's have better, more-complete welds (you can actually see the incomplete on-off-on-off welds on the crossmembers in the stock photo of the RC kit posted earlier), and the BDS knuckles are much beefier. I will say though, the knuckles in the pics of the BDS & RC kits for the Ranger look a little closer to being comparable than the same knuckles for a Tacoma are.
Both kits do lack options for rear leaf springs, but another way to ditch the ridiculously-tall (~4") blocks for something more reasonable, is to find a good set of 2-3" lift leafs and pair them with 1-2" blocks (having custom springs made is $$$$$). Up to 2" blocks aren't an issue (after all, Ford used them for almost three decades on the older Rangers).
As for cutting the mount off the diff housing... With as low-down as Ford put the damn thing, BDS probably thought the increase in clearance was worth doing it that way (in the RC install guide it looks to be hanging at least a good inch below the crossmember). I've seen some guys fret over cutting out the crossmember, but with the new replacement being so much beefier, I fail to see much concern there. Just save the old crossmember if you think you ever might de-install the lift, it can always be welded back where it was (the aluminum diff mount would be harder to reweld and have it be solid though, so probably would want to get a new (junkyard) housing in such case).
After looking at the installation of both kits I now agree that the RC kit is a better option. Less cutting, especially not cutting on the differential. The BDS appears to allow for about 1 inch more ground clearance on the front diff with their installation process is the real difference in my opinion. The other issue I have is the shop says they do not want to put my Eibach coilovers on the lift because they don’t stack lifts, which I understand, but they are okay with adjusting the stock coilovers per the instructions or installing other coilovers ie the Fox 2.5’s from the BDS kit (which I like by the way).
If you want to use your Eibach coilovers with the kit, you'll need to measure the drop-down amount at the kit's crossmembers, then check whether the kit's shock spacers match that amount to within ¼" or so (some (but not all) kits' spacers are significantly taller than the drop crossmembers and so is why your shop would have a concern about it). If the spacers match with the drop-downs, then there should be no problem running whatever shocks you want with the kit.
If they don't match, it might be possible to create suitable spacers yourself using various spacers you can get for $30-50 on Amazon or Ebay and bolting them together.
I don't know offhand what the '19-'23 ranger suspension's motion ratio is though (nor do I have info on the drop crossmembers for either k), so I couldn't tell you which actual spacers to buy (what their actual thicknesses are vs their claimed lift amount), but this should be easy enough to do once that info is known.
FWIW, these kits do not need upper control arms (UCAs), though it still is fine to use them if you want.
The drop-down crossmembers w/taller knuckles are what keep the suspension's geometry with the lift like how it was stock (this isn't the case with lifts that simply use longer coilover shocks that push the suspension (control arms) down for lift... You lose caster angle when you lift it that way, and so is why you need UCAs with a coilover shock lift).
(would anyone know offhand what the motion ratio for the '19-'23 ranger suspension is?)
WOW, Thank you. That is the best info I’ve gotten yet. 1st let me start by saying this all came about because I installed a new steel front bumper and winch. This caused the front droop slightly, but I can see the rack again. The Eibach’s I have now are so preloaded to achieve the level lift they are firmer than I want now. I want a softer feel so I thought the Fox adjustable 2.5 coilovers were the way to achieve that. The shop also suggested removing the 500 LBS springs and replacing them with Eibach’s 650 LBS springs. My only concern there is making these coilovers firmer and thus defeating the purpose of the new lift and coilovers and yes I want to make this beast more capable. I guess the real sticking point now is the new coilovers springs being made to firm with the addition of 650 lbs springs and waiting to hear from BDS about weather or not my 1 piece Tom Woods driveshaft is going be a problem.
I was guessing that's why the BDS 6" does not include new UCA's while the 3.5" kit does, so thanks for confirming.
If it's the Fox coilovers that come with 500lb springs, then 650 is almost certain to be too much.
A steel bumper + winch (guessing ~200lbs added weight) usually calls for about an 8-10% increase in spring rate, so if original is 500lbs, you'd probably want to look for springs that are closer to 550lbs.
