5.0 swap cutting out randomly while driving
Featured Build Threads
Fletch!
Forum Member
Ca
I have a 5.0 swapped ranger with a t5 and every time I floor it the engine cuts out and it sounds like a Jake brake. after it has cut out it is hard to restart with a jumpstart or just the key. any ideas? I just replaced the upstream 02 sensors and now I am at a loss.
P0135
P0141
P0155
P0161
P0174
P0460
P013502 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P014102 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P015502 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0174 System too Lean (Bank 2)
P0460Fuel Level Sensor Circuit Malfunction
So far all of those except PO174, I'd expect a blown fuse or broken wire. Any chance one of your O2 wires got against the exhaust and melted? That could cause all of those at once. IDK that it would cause the running bad, unless it's the bank 2 upstream sensor with bad wiring causing it all. IF you don't have broken/melted wires, I'd try replacing that sensor with the old one as a test.
I replaced both sensors with some nice new ntk ones and the problem is still present. I will look for burnt wires and fuses
Event Coverage
Featured Ranger Based Vehicle
