The $600 1988 Ranger. A semi-serious drag-n-drive project.
Featured Build Threads
Well, thank ya. It's been a fun project for sure! Really a culmination of all the stuff I have thought about doing for years. It's fun to see it come to reality. Crazy to think I started on it about 1 year ago.
Just remember, Rome wasn't built in a day and some of that quality construction still stands today. Patience, time, and detail have its rewards.
Worked a little on it today. I've been in a holding pattern waiting on parts to arrive, and the steering wheel stuff finally showed up.
Normally I try not to spend a lot of I don't have to, but the Motion Raceworks removable steering wheel kit is worth the money. It's a nice setup that bolts directly to a Grant 3 bolt adapter.
Everything went together pretty well. The hole in my inexpensive steering wheel was a skosh too small for the Motion horn delete button. I easily fixed that by opening the hole up with a drum sander.
Mounted the Terminator X and started routing the harness through the firewall.
It going to be interesting seeing how this generic "Ford" harness fits this truck. Preliminary lookys show it's going to be tight reaching everything.
I struggled drilling holes in a block off plate that I forgot I had not permanently mounted yet. Haha. Popped it out and it was much easier to deal with. Imagine that.
Trimmed the dash to get it to fit back in. Seems to be working pretty good. This dash pad is super crunchy. Haha.
Not bad for just eyeballing everything.
Mapping out all the electronics can be somewhat of a pain in the butt. Trying to find places to mount stuff that isn't in the way, but is not completely hidden and keeps the wiring lengths sane is a challenge.
I think I am getting my head wrapped around it though.
This truck will get an Accel 300+ ignition just like the 83GT has. I am trying to keep the majority of the "engine operation" electrical stuff on the passenger side of the engine bay.
I welded the outermost dash pieces back together. The plan is to attach them to the speaker grills so they can be installed and removed easily.
I tacked a piece of metal from the speaker grills to the outside pieces. I kinda like the "tacked together" look haha and it'll be better once it's all the same color. To remove it, you just take out the two grill screws and it all lifts out.
Because I have a gaping hole in the dash where the HVAC and radio once were, I picked up a 6 switch thingy with USB and 12v plugs. I have no idea what I will use the switches for but I have considered setting some of them up as bypass switches for things like the water pump and fuel pump. Mainly so I can cycle or run them without having to have the Holley powered up.
This is intended for boats, but I thought it would look ok in the truck. The round things are circuit breaker resets.
Made a steel plate to mount the switch panel in the dash. It's just 16 gauge sheet metal that I cut out with a death wheel that screws to the factory radio/HVAC mounts. I think I will space the plate out just a skosh to bring it closer to the dash panel.
I have no idea what I will use 6 switches for. I really just wanted a panel that was large enough to fill up the void where the HVAC and radio once lived. Maybe I'll put some underglow on it. Haha. Nope.
Poked the dash back in. I really wanted dark gray. This can said charcoal gray. Not as dark as I would have liked but I couldn't find any darker except black. All the blue colors I found were waaaay too blue. It's fine though.
Been messing with wiring some stuff. Not my favorite job. Hard to get motivated. Haha.
I mounted the Terminator screen on the dash. The Ranger has a good flat area right in the middle. Trying to keep it looking clean.
Event Coverage
Featured Ranger Based Vehicle
