why on earth would you want to bypass your MAF sensor?
and turbo cat, where are you getting those numbers? 6x 19# injectors wont even support 200HP at a rather anemic .5 BSFC (which i doubt your running boosted) with stock fuel pressure. even if you bumped the FP up to 60 PSI youd be pushing the limits again at 220HP....in fact, 19# injectors @ 60 PSI would probably be just about right for 5psi of boost (not the 12-13psi it takes to lay down 300HP).
tuning through the PCM isnt going to do you much for overall fuel flow. ford sets their injectors max duty cycle at 80%...if you were to electronically increase it much beyond that you'd start having injector reliability problems as the coils heated up. even if you did, at 100% duty cycle (static) the stock injectors would only support just over 200HP on stock fuel pressure.
