Wanted Duff Extended arms.
NakedDucks
B’ham AL
God’s plan, not mine.
Anyone got a set of James Duff Extended Radius arms they'd let go? Need the complete set with the frame mounts as well.
I know I can get them in the Stage 3 kit, but Im wanting to install on a truck that I don't intend to lift
@NakedDucks
When I bought them, Duff sold them to me ala carte.
Keep us posted how that works out, I have actually been wondering if extended radius arms would make much difference on a non lifted truck
Another set of factory arms and some 2 inch dia quarter inch wall DOM extends the stock ones quite easily.
Are you saying just extend the current arms using some tubing? Hmmm never even thought of that!!
I may try it… and build a custom crossmember.
I used 2x2x0.250” square tube. Cut the stock arms to where the tube nestled in. Plate the back with some 3/16” or 1/4” plate. Welded a threaded insert in and a joint from Ballistic Fab. I don’t know if I have any good pics though but I’ve done it twice so far
Tube extended radius arms are a pretty common mod. I used 2" .250 wall DOM round tubing and 2.5" Johnny Joints, threaded tube inserts, and 3/8" + 1/4" plate steel to make new frame brackets. I went 13" longer than stock so the frame mount is just forward of the stock trans crossmember (so I didn't add one).
In progress pic before final welding. In hindsight I shouldn't have heated the stub end of the old radius arm quite as much, it turned out to be brittle and I had to reweld it.
Final product pic before install with the passenger side frame bracket I made in the middle.
