4.0 SOHC Radiator Cap Swap
JohnnyO
Moderator Emeritus
Pittsburgh
PA - USA
Vehicle
Drive
2.3 EcoBoost
1.5"
Later model 4.0 SOHC engines have a 20 lb radiator cap. This is probably too high because they tend to get cracked thermostat housings and radiator tanks. Pro Tip: Swap to the 16 lb cap spec'd for a 1998-2000 Mustang V6 and t-stat housing and radiator failures are less likely to occur.
I just looked up the cap for the 2011. Ford Parts lists a 16lbs cap. Check your cap before ordering a replacement since you may have a 16lbs cap already.
