3.0 cold engine idle...
flyin-lowe
Forum Member
Law Enforcement
Indiana
My 17 year old son has a 2004 3.0 with around 120K miles on it. He called me outside a month or two ago when he started it and the RPMS shot way up. He is a new driver and said it sounded like the gas pedal was stuck so he shut it off. I popped the hood and had him re start it and it was high but not super high, it was idling around 3K RPMS. After 30 seconds or so it began to slow down. Haven't had an issue since but today I drove it and noted when I started it up it idled around 2200 rpms for about 30 seconds then over the next minute or so it go back down to the normal 1K RPMs. Today the temps outside were in the high 50's so assuming there is something in the system that causes it to idle higher in cold temps, it should have been effected when it's this warm. This is our first Ranger so I don't know a lot about the little quirks, is there a throttle positioning sensor or something, or anytihng else that could be going bad? It has not thrown a code.
It should idle near 1,000rpm until it warms up. At that point, the ecu goes into closed loop operation and pays attention to more sensors. It should drop to about 700rpm for normal warm idle. These numbers may be slightly higher with automatic transmission. At idle, the throttle should be closed. There is another valve called the Idle Air Control valve (IAC) that bypasses the throttle to control idle speed. First thing I would do is inspect the IAC and make sure it is clean and not sticking open. While you're there, clean and inspect the throttle. Also check throttle cable, linkage and pedal to make sure it all moves freely and isn't getting hung up on anything.
High idle can also be caused by vacuum leaks. Check all vacuum hoses and fittings for cracks, holes or disconnected components.
I am ordering a new Motorcraft IAC valve. I was re-reading your response. I assume if it was a vaccume leak or throttle cable the idle would not slow down as the vehicle warms up. Based on what I am reading it seems to idle little high anyway, normally it is right at 1000, maybe 900. But a few like I said, I started it and it was steady at 2000 and after a minute or so it slowed down to 1000.
I ended up ordering the new motorcraft unit (CX1946) and it did not come with a gasket. I have looked on youtube and some models show a paper type gasket, some show a small one piece two holed rubber or plastic gasket. Anyone no for sure which one these take or do I need to take it apart first.
I suspect either one will work fine, as long the bolts don't bottom out with the thinner gasket. Thicker rubber gaskets would allow for a slightly rougher finished surface.
If it idles high after installing the new IAC, don't worry untill you put a few drive cycles on it. My IAC was sticking a bit and after I cleaned it nothing changed until the next day after driving to work and back.
Sorry for the delay, the new IAC took care of it. It did take some time to find the gasket though. None of the local had them in stock, but had one the next day.
Normally they come with a new gasket. But some people probably buy and return them a lot and take the gasket.
Thanks, I don't use Rock Auto much but noticed the last two items I purchased did not come with gaskets. This valve and a fuel pump I bought last year.
Upcoming TRS Events
Featured Ranger Based Vehicle
