2011 Ranger XLT 4X4 - "Business Casual"
Featured Build Threads
A bunch of random photos I found to help out for placement of brackets, bumpstops, gussets, etc.
Dropping them here for others in the future.
Also, for posterity:
My setup is a combination of both the North Peak 4X4 and Rick's Rangerz bracket kits.
The brackets themselves are from Rick, gussets and bumpstop brackets are North Peak. Both have pros and cons: North peaks gussets are nicer, and have the bumpstop brackets you will need, Rick's customer service is unparalleled and his brackets are nicer.
YMMV, this mod can cause uneven tire wear.
Looks good.
I would have made all the springs the same color.
Looks good.
Not my setup, just random ones I found on the internet.
I opted for silver. Trying to keep the truck devoid of color other than greyscale
Some electrolysis before and after:
After a 12 hour run:
The foam is a mix of sodium carbonate, oxygen, and hydrogen. Pls don't smoke around it.
After a 12 hour soak, all paint is Chassis Saver:
After pressure washing:
If anyone was curious, a lower control arm does fit in a standard electric oven
Trying to document the coilover swap as much as possible, I find myself using more and more components from both kits. The Rick's lower brackets are quite nice, but don't have the shock absorber divot spacer plate necessary to go under the bracket and keep it level like the North Peak kit has. Rick's kit is also lacking the spacer to put above the upper coilover bracket, so I used the North Peak one for that as well. Install photos to follow once I get the bump stop relocation worked out.
Should note that the North Peak kit does come with a bump stock relocation bracket, Rick's does not.
Currently haranged thanks to FedEx breaking my new upper control arms, and RockAuto shipping me the wrong lower control arm bushings. If anyone wants a set of upper control arms with snapped off grease fittings, let me know, free + shipping.
Featured Ranger Based Vehicle
