2008 4.0 SOHC exhaust recommendations
Felt
OK - USA
Vehicle
Drive
I am planning on upgrading my exhaust to make my 4.0 v6 4x4 extended cab ranger more impressive. There is no such thing as too loud for this build so long as it is crisp and avoids too much drone in the cab.
My main goal is to make my pickup more impressive while driving down the road and to allow greater overall performance out of the exhaust.
Right now I am interested in the Flowmaster 40, magnaflow, and MBRP. I am VERY open to other recommendations and experiences with these exhausts.
Son, ain't nobody impressed with a ranger except for the old farts on this forum and the kind of girls that you probably don't want to date.
☝🏻☝🏻☝🏻 he's right you know.
You do you though, of course.
A CRISP sound is gonna require headers. When you mix stock manifolds and additional volume the outcome is generally always just kind of a garbled mess that sounds like an old tractor. More performance is also header territory.
A simple muffler change will make an imperceptible difference in power.
I put an MBRP cat back on my truck. Nice stuff and fit well.
Yeah, definitely headers. Personally I kinda like how headers sound with a Flowmaster 40/super 44 on the 4.0 motors.
That said, I really like the sound of my 5.0 through headers, true duals and a Magnaflow crossover muffler. But you’ll never get v8 noises out of a non-v8.
Also, your biggest performance upgrade would be to throw a shift kit at that automatic transmission.
I had a flowmaster 44 on my 03, sounded ok at low RPMS, but like a swarm of bees at higher RPMs
That^. I prefer to be able to sneak up behind a person standing in a parking lot. Too bad my brake/wheel bearing roar gives me away.
What’s a good brand
What brand makes a good set of headers for the Ranger? Also I know it heavily depends on the vehicle, some are simple and some are a pain, but how challenging is putting new headers on the 4.0?
What’s a good brand
No idea what brand to recommend for headers on a 4.0, I bought my set long ago and don’t remember the brand.
The biggest challenge is usually trying to get the exhaust bolts out of the heads without breaking anything. Rust is a huge issue here, your results may vary. For the motor in my Choptop, I removed the stock manifolds with the motor on an engine stand so I had plenty of room to work before I dropped the motor in the truck and put the headers on. That isn’t always an option though. If the bolts come out nice, it shouldn’t be a big deal to swap it out in the truck.
Headers are a semi crapshoot.
On the one hand, yes, they are *sometimes* better than manifolds.
However, with a 20 year old catalytic converter and im presuming no wideband and tuner, they're almost entirely useless except as bragging rights and a 1-3% bump in torque somewhere on your rpm range that you use 3 times a year.
Now if you tune, whole world of possibilities.
If you want to make your Ranger better, start with upgraded brakes and tuning the stock truck. You really don't need parts to get more out of your engine with a good tune. Added benefit is that you now have the magic wand to make the most out of every further change you make.
But what do I know about tuning.... 🙂
Further reading, a 3.8 T-Bird running 400 rear wheel horsepower:
Here's the important part:
"The only other thing I will add, is that it is no small thing to be aware that this motor does this with stock exhaust manifolds, emissions legal cats, and a full rear exit, quiet exhaust system. The car is fully streetable, is daily driven, and passes OH E-check with flying colors."
Put a loud muffler on if you want.
Performance doesn't come from glasspacks or a Dynomax box. Performance comes entirely from modifications with goals and most importantly, *tuning.*
Not beating up on ya, guy. But for the same money as a JBA exhaust system, you can unlock your PCM and get more out of the truck. Youtube how to do a burble tune if you like loud, annoying stuff. 🙂
