2001 3.0L Water Pump Replacement
mcgee
Forum Member
Firefighter
Northern California
28x8
Need to do a water pump on my 01’ ranger and it’s my first time doing one on this truck. I have done them on older f150s but that’s about it. I have seen a few videos but some say you have to remove the AC and power steering bracket in order to replace it. Another says you need to drain your radiator and remove the tranny cooler lines. So i’m just wondering the easiest way to replace it. I have to replace the fan and the fan clutch aswell.
I have never worked on that engine. But you can take a look at it, many times on their engines Ford did use the water pump to support other brackets. So taking the power steering pump and A/C off is not unusual. You do not need to disconnect them totally, just take them loose and sit them to the side with their lines still hooked up.
If it's tight in front of the engine, taking the radiator out may be good insurance, it's very easy for a wrench to slip and you poke a hole in the radiator. You will have it drained anyway, and they usually pull straight up once they are disconnected.
Welcome to working on a newer vehicle. Many unrelated things have to be disconnected to do a job sometimes. And that increases the chances of making mistakes. We all do it. While you are in there, check the condition of the belt or belts, the radiator hoses, and any other bits and pieces. If the 3.0 is like most Fords, the waterpump/timing cover may be corroded. So check that out to prevent leaks. A little rtv will usually cure minor problem areas.
This isn't a particularly difficult job.
It's been a long while since I've done one but IIRC the bolts don't go through the timing cover like a 302 so the usual screeching about snapped bolts doesn't apply. I forget if you have to pull the driver's side accessory brackets. Either way not a big deal.
I wouldn't open the trans lines unless you get to a point where you have to. I'm like 99.9% sure you don't need to pull them at all. Removing fan from the water pump before pulling the pump will make things much easier.
Ive done many......
Leave the ac & ps bolted together...
But yes, you need to unbolt the combo of the 2 from the block to access I think 1 water pump bolt....
I actually leave one of the bracket side bolts still in the block, the one furthest back,
Just loosen it, & then I get a ratchet strap draped over the driver side fender attached to the wheel & give it a few cranks.
That will pull the ac comp & ps bracket away from the timing cover & wp to gain clearance access to replace...
The hardest part is wacking off the fanclutch with 7/8 open end wrench, prior to doing anything....
Need to hit it the right direction or will make things worse & theyre usually really tight.
Key is to swing the sledge hammer downward on the box end of the wrench & not just swing across...
The fan shroud may state what direction to turn the fan clutch to get it on.....
This works really well for removing fan clutches… hook it on the pulley bolts and it holds things steady.
No need to hold the engine steady....
The bolts on the 3.0 are inset behind the pulley lip, that tool would be worthless...
Ok, so it’s been awhile since I’ve worked on a 3.0 apparently, lol. I’m so used to 4.0 and full size truck motors anymore that I didn’t give a thought the 3.0 could be different. My 3.0 is currently a half hour away and I haven’t done anything to it but move it to its current location in the past like 10 years.
Yes, the 4.0 fanclutch tool had an attachment to grab the wp pulley bolts.
But as a tech we just smack the tools with a hammer....
You use the 2 tools to treat them like 2 wrenches & dont pound on them.
Majority of the time, im taking fan clutches off with just a blunt tip on my air chisel....
I used to do it that way until I had one that wouldn’t come free. Neighbor loaned me a Snap-On tool but even that didn’t work well. Came across that wrench, tried it, and love it. At most I give the wrench for the nut a love tap with a deadblow if using them like wrenches isn’t cutting it.
