Kuper
- Mar 31, 2018
- 2.9 V6
- Automatic
first of all what a pain to get to some of these bolts!
I am almost done putting in a used 2.9 engine that I picked up cause
my blown head gasket lead to ruined cylinder walls.
I did the following
-rear main and front seal
-new gaskets
-new timing chain set (due to finding tensioner in pan)
I should have bought an oil pump but I cheaped out I cleaned screen best I could
used engine assembly lube various spots
added oil and primed using a old distributor with drill
I Just forgot to take really good photos and my tape I labeled smudged off so
things I need help with maybe photos if possible?
-where does the positive battery lead mount up to midway to starter?
-which spot does oil dipstick bolt up to on exhaust manifold?
-a/c pump picture?
might be more struggle but that is all for right now
any help is appreciated thanks
I did the following
-new gaskets
-a/c pump picture?
