2.8V6 Looking for deep exhaust tones, need ideas
J_D43
Forum Member
Bonneau
SC - USA
Vehicle
Drive
2.8L
5"
31x10.50-15
As the title says, im getting ready to run some new exhaust on my 85 with the 2.8 v6 and im wanting to get the deepest tone i can out of this smaller v6 while avoiding raspy or high pitched tones. Just wanted to see if anyone had any experience or ideas on what setup i should run
:iamwithstupid:
In all honesty, nothing you can do to the exhaust will make it sound like a v-8, so if that’s what you’re hoping for, only a v-8 makes v-8 noises.
That said, personally I prefer the sound of a 2.25 or 2.5” exhaust, high flow aftermarket cat and a Flowmaster 40/super 44/super 50 for the Ford v-6, seems to sound the best if you want a little aggressive. Headers also help. My 5.0 has a Magnaflow crossover muffler and dual exhaust with headers so I know what nice v-8 noises sound like, lol.
Don’t use a Flowmaster 10 series. Punk at the exhaust shop insisted on it for my Choptop and it annoys me, but not enough yet to buy a replacement yet, which will probably be a 40 series like what has been on it and like how I had wanted.
:iamwithstupid:
Definitely not expecting it to sound like a v8, I just know next to nothing about mufflers and i want to make sure I'm not buying something that's going to make my exhaust sound like a bag of marbles being violently shaken in a paint can
I've heard quite a few people suggest the super 44's for these smaller V6's as you said
I don't like loud exhaust, but do like a deep mellow tone.
When I got it, my 84 2.8L had long tube headers (plus Holley 4bbl and Offy courtesy of my dad many years prior), but was in bad need of a new exhaust. Carried it to a local old-school muffler shop, they installed 2.25" dual exhaust with generic turbo mufflers, over the axle and existing rear corners of the bed. I couldn't have asked for a better sound or volume level.
I really wish I still had a video of it running with sound, but pretty sure I lost the one I did have to Fhotopucket going paid.
When I put the F-100 on the road several years ago, I had a similar system installed on it, except for 2.5" exhaust and shorty headers to clear the 4x4 bits. IMO it sounds better there, but that's a 360 FE V8, so not a fair comparison.
It seems like we both enjoy the same sound, i'm definitely between super 44's or a 50 delta flow. I honestly think im leaning towards the delta flow just to make sure there isn't any rasp
Im with you there, the nice thing was about the squarebody i had with a 350 small block was that you could toss most anything behind it and it would sound good, as is with most V8's
The mufflers I was running on both were literally generic turbo mufflers. No name stuff that the exhaust shops kept on the shelf. Probably Walker or something.
I think the latest shop put Magnaflows on the 99 V8 swap truck. Honestly, louder than I like. Not bad sound, just too much volume. I suspect part of that may be that it exits too close to the cab. I suspect that going over the axle and exiting at the back would help, but they said no room for it with then current suspension config (very much lowered).
Deep notes come from bigger cylinders. Same way a bass drum has deeper notes than a tom-tom or a snare. Adding a resonator can help get rid of some frequencies and reduce drone. Larger diameter pipes may help give lower notes. But that can only go so far with small cylinders. Plus, pipe diameter can affect performance - some mumbo jumbo about exhaust velocity and scavenging. You don't want to go too big. You can google best exhaust pipe diameter for different engine sizes. It's an art with a lot of give and take and sound isn't necessarily where you want to put your priority.
Years ago i had a two point eight v6 with headers in my MGB. I went with dual exhausts and glass packs on it. Everyone thought it sounded like a small eight.
V-8's sound unlike anything else because they are 2 odd fire 4 cylinders hooked to a common crankshaft. Odd fire sounds put off the low rumble. You'll even here kind of a similar thing in Subaru's with dual exhaust. Build some headers that swap a cylinder from one bank to the other. Uneven collector pulses will make it sound like v-8.
Or you could do the 2 chamber Flowmaster thing, it was pretty popular on the small v6's back in the day.
@J_D43
Instead of attempting to make a Cologne 60° by sound like something else, consider making it sound good.
A stock 2.8 or 2.9 with a set of JBA* headers, 2¼" tubing and a single Borla Turbo muffler (now renamed the ProXs line) is near dead quiet at idle or under normal driving, WOT and in its subtle way, sounds magnificent...but nothing like a V8, IT NEVER WILL.
@J_D43
Instead of attempting to make a Colonge 60° by sound like something else, consider making it sound good.
A stock 2.8 or 2.9 with a set of JBS headers, 2¼" tubing and a single Borla Turbo muffler (now renamed the ProXs line) is near dead quiet at idle or under normal driving, WOT and in its subtle way, sounds magnificent...but nothing like a V8, IT NEVER WILL.
Good point. I never did a side by side comparison. Who has? I didn't really care. I just know that little motor sounded great.
@J_D43
@J_D43 To add on I want to say this is true. Right now my 2.9 has a set of headers, original 2” exhaust, and a Walker Quiet-Flow, and it’s perfectly deep enough to sound like a “truck,” and maybe even a V8 to casual people. It’s also quieter than the Borla’s numbers with approximately 67-70db at idle by my own readings, as opposed to around somewhere around 80db taken from other forums.
It really doesn’t take much to get the 2.9 sounding really good, and I think if you’re doing a completely new exhaust for your 2.8 it’d be worth fabricating some headers if you can. Those and the Walker are the only things I’ve done to the exhaust, and my truck sounded like a usual little V6 before the headers went on. My opinion is that headers are probably the most important aspect, with the muffler secondary, BUT, if headers aren’t feasible, you can offset it with your muffler to an extent.
ALSO consider a resonator. I’ve heard nothing but good things about Vibrant’s Ultra Quiet model deepening the tone.
If only those were still available for the 2.8L. To my knowledge they haven't been in a long time.
edit: fix typo
Upcoming TRS Events
