That's excellent advice; thanks for bringing it up.
@MadMax_636 -
I wouldn't even mess with splice S207. Did you mean splice S128 instead?
The pictures in your post #168 (page 12) look to show splice S128, where the Brown / Pink START wire joins the White / Light Blue dashed RUN wire, between C102 and C107. If you're using the Brown / Pink wire for your ignition power, and it tests as +12v (hot) in key positions RUN and START, then you shouldn't
have to reconnect the two wires at S128.
But, it won't hurt anything if you do reconnect these wires. Actually, restoring this connection (splice S128) puts your wiring back closer to the stock configuration, and will probably make it easier to clean up (loom) the harness once you do have it running.
