- Jul 30, 2022
- Fairborn, OH
- 3.0L
- Automatic
Hello All,
Just got this as my first DIY and learning a ton in the process. I am a computer nerd but have always been more of a fix it yourself kind of guy.
Trust me when I say, if you are reading this you know more than I, but I am willing to listen and learn.
Based on all that I have read and watched, here is where I am.
Vacuum issue:
1. Checked all lines concerning the vacuum system, none seem to have cracks or leaks coming from them.
2. Noticed everyone talking about Heater Valve Vacuum, but my truck does not have one. Figured out that someone had bypassed it and now the lines always run to the heater core(more on that later).
3. Finally found the vacuum reservoir, this took an embarrassing amount of time so its part of the step for me. Took off the incoming and noticed it had good suction, out going had nothing.
4. Ordered the vacuum reservoir and will update later this week when I put it on.
Engine is overheating:
1. After running for 20-30 mins and shutting off, noticed coolant was coming from the radiator cap and coolant reservoir. (Only used 50/50 to fill system)
2. Ordered a new cap for the radiator, seems to have stopped the coolant from spraying from the top. (after topping off the reservoir to the cold fill line)
3. Engine still not cooling properly. However it doesn't seem like I am leaking any coolant. Radiator fan seems to be working properly.
4. One thing I noticed is that I cannot get heat to come into the cabin. It is 85-90 degrees most days here so you would think this should be easy.
5. I noticed that the incoming heater core line is hot but the other is not. I am guessing something is blocking it so I will try a flush.
6. Ordered flushing tools for the heater core and will update after I flush it. Not even sure if the blockage could cause the engine to overheat, but there is no heater valve either as someone has bypassed this and plugged the vacuum line.
Any thoughts on any of this would be great, thanks for your time.
Vacuum issue:
