1998 lift kits
Featured Build Threads
Dangerranger1998
5+ Year Member
I own a 2wd 1998 5speed and I'm looking for a lift kit can anyone help me out?
coils or torsion bars up front?
how big lift?
I would like a 3" lift
Sent from my XT1080 using Tapatalk
I heard people do a spindle lift in the front is that something I should consider doing?
Depends what you're trying to achieve with the lift. Will it be a daily driver or a truck to do some off-roading in? Here are some options;
3" Body Lift - About $200 and about a long days or weekends worth of work. Suspension geometry is unchanged so the truck drives similar to stock.
Front Lift Only
3" Spindle Lift - About $500 (Fabtech) and an hour or two to install. Retains a stockish ride. Cuts down steering radius.
2"-3" Coil Spacers - About $30-$40 without shocks. Might be a pain to install depending on your spring compressors and patience. TRUCK WILL MORE THEN LIKELY DRIVE ROUGHER. Might also stress out the upper ball joints.
Rear Lift Only (All require new shocks)
Blocks ($50ish - Ebay or Amazon)
Shackles ($50 - Belltech 6400)
Add-A-Leaf ($50 - Fabtech)
Hope this helps a little!
Upcoming TRS Events
Featured Ranger Based Vehicle
