1997 2.3L Exaust
Sudo
Forum Member
Tenmile
OR - USA
Vehicle
Drive
2WD
2.3L
I bought a Truck that doesn't have a Cat. I want to put one back in. The former Owner used a straight pipe ( with the sensors installed) and a Trash Muffler. That's it. Not even a endpipe and the muffler sits in the wrong spot.
I saw on Amazon a Cat for 120 Bucks and one at Rock Auto for around 200 Bucks and one for almost 800 Bucks.
Will the $120 Version work? What's the difference between the cheapos and the expensive ones? The one for $120 is a Universal one.
AFAIK the only difference is stock fit or universal...
You will need to look at the emissions standard the truck was built to as well. That will partialy make the deicision on what catalytic converter to get. Legally, if it has California emissions, it needs a California compliant model. If it has 48 states emissions, it opens up the door to more options.
My F-150 has a weld-in factory replacement cat. I couldn’t afford a whole exhaust piece at the time and the cat on that is a dual in-single out deal, so it just made sense to do it that way.
Everything else that I’ve messed with the exhaust has got a universal fit cat welded in by the exhaust shop when I get a full stainless system put on. Only way to go, buy once, cry once. Around here, anything cheap usually doesn’t last more than 2 years. Rust is a miserable cancer that never rests.
Thanks for all the advise.
I made it easy for me, I got me a parts Truck for 400 Bucks. Comes with a hitch, good Seats , good Airintake hose and a dent free Bed. . Right there i got my 400 Bucks back.
The Truck got also a driver side back window that opens.
So , I came to the conclusion to build me a ...........Stranger B23xl
My Truck is a 97 Ranger xl and the Parts Truck I got is a 95 B2300. I'll use a bunch of Bodyparts from the B2300 on the Ranger. Also the complet Exaust with Cat.
Upcoming TRS Events
