1996 XL Ranger Seat Replacement
Montrose
CO - USA
Vehicle
Drive
I just bought a 1996 Ranger XL for my son's first car. Figure these trucks are everywhere in western CO and seem to go most places he will need them to go. There are a couple issues with the vehicle. The first one is the speedometer and odometer are not working. Can these be replaced easily?
It also has a bench seat that is a little used. I was just going to get him a seat cover but maybe we can put some other seats in it. I was looking through previous threads and the information I found about seat replacement was for the extended cab. Hoping someone might have some information for me.
After buying this truck for my son, I'm really wanting one now! This truck is fun to drive and I'm hoping he really loves it. It's a gift for his birthday.
On the speedometer, there's a sensor on the rear drivers side of the transmission with two wires, pull the bolt that holds it on and see if the gear is in good shape and you might need to try a new sensor, if the wires are chewed up that would be the problem
On the seat, is it a split bench where each side moves individually or a full on bench seat? If it's a full bench seat you'll need the seat brackets from a similar Ranger, don't remember the year ranges but could be '93-97 then they should nearly bolt in from there.
congrats! The speedometer issue is pretty common. You might want to check the sensor and wiring at the back of the transmission first—sometimes just replacing the sensor does the trick, or it could be a worn or shorted wire.
Event Coverage
TRS Merch
