1996 XL Ranger Seat Replacement
Featured Build Threads
Montrose
CO - USA
Vehicle
Drive
2.3L
I just bought a 1996 Ranger XL for my son's first car. Figure these trucks are everywhere in western CO and seem to go most places he will need them to go. There are a couple issues with the vehicle. The first one is the speedometer and odometer are not working. Can these be replaced easily?
It also has a bench seat that is a little used. I was just going to get him a seat cover but maybe we can put some other seats in it. I was looking through previous threads and the information I found about seat replacement was for the extended cab. Hoping someone might have some information for me.
After buying this truck for my son, I'm really wanting one now! This truck is fun to drive and I'm hoping he really loves it. It's a gift for his birthday.
On the speedometer, there's a sensor on the rear drivers side of the transmission with two wires, pull the bolt that holds it on and see if the gear is in good shape and you might need to try a new sensor, if the wires are chewed up that would be the problem
On the seat, is it a split bench where each side moves individually or a full on bench seat? If it's a full bench seat you'll need the seat brackets from a similar Ranger, don't remember the year ranges but could be '93-97 then they should nearly bolt in from there.
congrats! The speedometer issue is pretty common. You might want to check the sensor and wiring at the back of the transmission first—sometimes just replacing the sensor does the trick, or it could be a worn or shorted wire.
Sensor in the rear axle can be an issue, but there is another common issue for the speedometer and odometer not working. There’s a little plastic worm gear in the gauge cluster that has been known to break. Last I checked you could pick up a new one for like $10-15 (stupid expensive for a tiny plastic gear but whatever). Little annoying to get to because you have to tear half of the dash apart but not really a hard job. Take the cluster apart and stick the new gear in there and good to go.
About 5:20 is where I start talking about replacing that gear, the first bit is all on the V8 swap stuff
The sensor on the rear axle wasn't used for speed until '98.
I just saw this was in the 4x4 section, if 4x4 the sensor will be on the output area of the transfer case not the transmission, same drill though.
It's a full bench. I need to find a auto yard to see if I can find the seat brackets. Thanks for the info!
Thanks for the video!
Any Ranger/Bronco II/Explorer seats from 83-97 can be used, you just need single cab tracks for them. I think Explorer seats may even be the same through 2001. Your floor may not be drilled & tapped for 60/40 or buckets though, usually bench seat trucks are not - but that is an easy problem to solve.
Yes, I skipped that step before, the center bolt holes aren't likely drilled in the floor but there should be dimples in the right places... in Rangers 60/40 seems to be the most common option but they have the right tracks on them, from there you can bolt many other Ford seats right on like Mustang, Explorer and I think Escort and Tempo seats, there's a list around somewhere...
I've also got a 96, 5spd, manual, with extended cab. I had issues with that speedometer as well. It was a while back, but I remember pulling the dash apart and found that the plastic gearing inside the dash was messed up. I put it back together, I think I also put some goop to lubricate. That fixed the problem. I must admit I still have an issue with the trip odometer and zero'ing out that, but I'll live with it as long as I can track my oil changes with the main odometer. Hope you got him the manual version of the truck. Love that truck. I replaced the top header with a great bright red material from on-line. I also pulled up the rug and painted the whole floor with black bed liner paint. Then when I had some interior parts apart, I spray painted the panels with red paint made for plastic panels. Looks like a brothel now. Wish my son would be happy with a ranger. He's got a taste for higher end cars. Bought him 2 $1000 cars, a 2006 Mercedes and a 2009 BMW. Big mistake. He's made a full time mechanic out of me.
90s and 00s Subaru seats use a "close enough" bolt pattern in the fore-aft direction (it's like 1mm off or something inconsequential like that) and a substantially wider bolt pattern in the left right direction. You can just bolt them onto your existing seat slider frames with some unistrut (use the half height stuff, the seats are gonna be a bit taller from the get go) to adjust the side to side spacing and big fender washers. These seats offer a fuckton more support in every way than the stock split bench.
Beware doing this in a single cab though as the seats are substantially bigger have a slightly more reclined position so you lose rearward travel from hitting the cab wall.
Event Coverage
Featured Ranger Based Vehicle
