1996 Gauge cluster light bulbs keep going loose
Featured Build Threads
sebastian323
Forum Member
Merced, CA, USA
4.0L
Hello, The gauge cluster bulbs on my 1996 XLT keep going loose. I know for a fact they are not burning out, because I have replaced the bulbs and inspected them afterward, But it seems every time I change all the bulbs and reinstall the gauge cluster, after a little while a bulb goes "out". I changed the bulb sockets with some new ebay ones and it still does the same thing. I am wondering if anyone else has had this problem.
I also ordered a bunch of LED replacement bulbs, but they illuminate the gauge cluster unevenly so I decided not to use them.
A pencil eraser is good for shining up the contact pads on the cluster circuit board. And then taking the bulb and pulling it in and out of the socket about 5 times usually fixes for me for several years. If you keep having a chronic problem, you might have to get some of that clear grease and put on the bulbs and the sockets after you clean them up really good.
+1 ^^^^
LED bulbs do have a + and - side unlike incandescent bulbs which can be installed either way
So after installing LED bulbs test that all come on, if a few don't then reverse the bulbs in the socket and reinstall
What part is coming loose?
The socket to cluster or the bulb in the socket?
There are 2 wires that each power 3 bulbs, so if you are losing 3 bulbs at once then check the wires from the dimmer on the cluster connector
The 6 Bulbs are at bottom of diagram, its shows which 2 wires power them, they share a common ground, 1 wire
1996 thru 2003 clusters are interchangeable, with or without tachometer, wire is there for tach on all Rangers
If it comes to that :)
+1 ^^^^
I bet I put the LEDs in backward
so there is no 4x4 or manual specific cluster ? I do like having the indicator light to show if I am in 4 hi, etc
1996 to 2003 clusters came with or without tachometer, and of course white or black face
All the indicator lens's are there just not wired if its not needed
i.e. 2WD or 4x4
OD on/off lens is there even with manual trans
Cruise Control lens as well
i.e. 2WD or 4x4
Good to know. I may grab another cluster from a 2003 when I run into one at the junkyard before they become more scarce just to have a good unit on hand with less age on it. The LEDs I installed dont really illuminate the cluster evenly, so I think the bulbs where better, but it was exctly like you said, I put the LEDs in backward so I reversed the polarity on any that werent lighting up and now they are good to go.
Upcoming TRS Events
Featured Ranger Based Vehicle
