- Oct 15, 2007
- Manual
Those buckets are sweet. Keep up the good work!
Plus, 9" of lift on a trail rig running 35's is WAAAY too much lift.you must also take into consideration that the coils will "settle" some....
l8r, John
If you havent already you need to roll the truck around a little before you go making changes. When you jack up a TTB front end the tops of the wheels swing out and the bottoms swing in as you know. When you just lower it back to the ground the axle and wheels will have some binding with the floor untill you roll the truck and let the TTB return to its static position.
