1993 frame info
maga1982
Plymouth, Indiana
I've read several posts and comments on the web about the removable rear frame section and how the 1993 to 2011 range should have them.
I have a 1993 Ranger Standard cab Long bed, 4x4 with a 5 spd manual 4.0 and it is a one piece full frame.
is this truck an oddball? Or are the people saying this wrong?
It has a manufactured date of 08/1993 and the vin starts with 1 so I know it was manufactured in the U.S.
I am also wondering if the Mazda trucks had a 1 piece full frame?
93 to 97 (3rd gen) has solid frame rails. 98+ (4th gen) has a 2 piece frame that is riveted together (right behind the cab) and you can cut the rivets to replace half.
I believe the mazda trucks were 1 year behind rangers, so a 94-97 should be a direct swap for frame/drivetrain etc - everything except the sheetmetal.
Yeah, the two piece frames started in 98. They were joined at the leaf spring hanger.
I guess instead of "sheetmetal" I should have said "exterior styling" cause that includes headlights, grill, etc - all the other stuff that is exterior but not made of sheetmetal.
