1988 ranger 2wd with 51/2 in superlift
ronnie918655
I have a ranger 1988 2wd with superlift 51/2 inch lift kit,drop i beam brackets etc. One problem,as my ranger is a 4 cyl 2.3 there is not much weight in the front. The lift actually added 7 1/2 inches lift. I have positive camber problems,and have changed camber bushings to 2.5 degree but still not enuff. Does anyone know if 3.5 degree camber bushings are available from any aftermarket companies. I contacted superlift and they tell me they dont have bushings over 2 degrees. I know bushings of up to 4.5 degrees are available for 4wd but am not finding much for 2wd. any information would be greatly appreciated. :sad:
your always going to have camber issues with ttb but with that much lift your drop brackets probably arent long enough.
If you don't need that much lift, I would put different springs in it. 4 inch lift springs may be worth a try. Have you driven the truck yet? The springs may settle out quite a bit once you drive around and hit some bumps. Edit- Wouldn't happen to be in driving range of Baltimore, would you? I have an extra set of 4 inch lift springs I'd let go at $50, but I'm not mailing them.
