1973 courier/ ranger build
Good progress!
That engine bay is tiny. :icon_welder:
This will be pretty cool, I'll be watching this one!
Sent from my Pixel 2 XL using Tapatalk
Well after some consideration and the fact that I'm not in a hurry to slam it together I think im going to just cut out the factory cross member and build a new one out of box tubing. It will look nicer then cutting and patching factory one and I can get the motor where ever I want it to sit. I'm not certain yet buy I hope I can tie motor mount into it and make the front stronger from doing it this way. I find a few days in between working always makes the excitement build before doing the work so I'm just going to sit and stare at it for a bit and read some more build threads . By then I'll be so egar I won't stop until I have it slung in there and cleared.
I am a machinist in a big fabrication shop building industrial stuff buy watching some of the guys fold parts and fit stuff up makes my floor and tunnel seem relatively simple in steps so more staring and thinking hopefully will make building flow the way my brain thinks it will.
Sent from my SM-G930W8 using Tapatalk
I spend a lot of time staring at my project and thinking about how I’m going to proceed
Years ago, when my interest in boat building was closer to the "front burner", I remember people in that realm talking about having a thinking chair in the shop. A comfortable chair positioned so that the builder could sit down, relax and look at the project. A place to contemplate what has been built, what is coming next, different design options, and occasionally dreaming about using the boat on a favorite waterway.
There's a lot of wisdom in having a thinking chair in the shop.
Eric B
Eric B
Yes. well with modern technology we have a camera on us most of the time and when we are dragged to the mother in laws or some other function we aren't always keen on we have the opportunity to pull it out and look at it and think about it.
Even at my job when doing some repetitive task where my mind can wonder I love pictures. The ones I post are just the tip of them. I also am good friends with the drafter/designer at work a fresh set of eyes can give you a simple solution.
Projects like this can be like art. Sometimes you don't know what to admire more, the way the truck functions, or the creativity and work of the builder. Take you're time, you'll be happier when it's done.
Thanks Jim and yes I'm not in a hurry to build it. If I hurry I'll just want to buy another project and be disappointed with how I did something. Not to mention the -40 weather we've been having and my heating system isn't comfortable at this temperature
I havent messed with leafs in the front before but now that I'm putting the motor in i have some questions.
I have to notch the frame to clear my alternator that's down low i can't move it up because of turbo and piping. If you look at the picture i notched it already a little but I'm wanting to drop it down minimum 1.5" lower but 2.5 will be likely where I end up. Along with that I need about .750" over to center the motor but once again more clearance for tightening belt stretch.
I have to build some sort of sub frame for my leafs anyways.
What's some insight on this. I'm sure I can put something together but fresh eyes can simplify my project. I'm going to put the cross member at the back of where the original one was as it was a u shape and fat. the 2x4 box I have should give it all the clearance there any ideas?
Well after 3 hours got the front suspension pulled apart and out of the way. Man do I miss the plasma cutter and torch at work for something like this getting a zip disc in there to cut out was a challenge ended up having to cut the coil bucket In half just yo get clearance and ya wasn't fun but hey it's done and shop is swept up ready for grinding all the sharp away and start measuring up to build the cross member.
After looking at the front axle and measuring not as I thought either but that's the way it always go. get your mind out of the way don't over think it and boom step by step
Your seats look almost identical to the ones I put in my '85. The guy I bought them from said they came out of a Nissan, but couldn't say what model. The tracks were too wide for the Ranger, so I welded a couple pieces of angled steel to the bottom, and mounted the original seat rails to those.
These are out or a Subaru outback. Yea the rails are gone just going to make up a frame and solid mount them where they fit for me floor has to be 're engineered anyways so I can make it work
I used to drive one of those when I was a teen delivering parts for NAPA. Good luck should be a nice truck when done.
