1" body lift for 2002 4wd
mrscullini
wasn't sure where to put this thread, but here goes. i have an '02 4wd. i want to install a 1" body lift. i purchased 2" blocks and cut them down. i intend to cut the fan shroud and relocate the front bumper. any other snags or considerations. i am thinking it should be a pretty straight forward job.
thanks for the insight.
You shouldn't have to adjust or extend anything much. IIRC, you should be able to adjust the bumper rather easily by just sliding it up. You should be good.
just keep a eye on things like ground straps, evap lines things like that.but by all means you "Should" have no problems with any of those things.
just a thought, airbag junk, I have no clue about it.if anything would be affected or not . thats the only thing I would look in to.
would suck to turn on the truck and get a black eye etc lol..
do you think the oem body mount bolts will be long enough for a 1" body lift or will in need new bolts?
