08-10 superduty steering gear on TTB Ranger
Featured Build Threads
holyford86
Some guy with a problem
⭐Supporting Member
💻 TRS Socials
Boosted (Not Stock)
Plattsburgh
NY - USA
many
Vehicle
Drive
33x12.50R15
I have recently acquired a 08-10 superduty steering gearbox in usable condition. I've read conflicting information on whether it would help with steering effort, as the factory box doesn't seem to provide the reduction in effort I'd like. It seems that the 11+ box is kind of the way to go but requires some extensive frame modification to work on a ranger, which ideally, I'd like to avoid.
I guess what I'm asking is, would this be worth swapping in? And is there a way to get this to work with the factory linkage? Currently running a 33 inch tire and a drop pitman arm on a D35, with a low mile 4x2 ranger factory steering gear and a Cardone saginaw pump. I would also like to avoid using an assist ram if I can get at least some of the way to that level of assist without one. Lines aren't an issue, I'll run adaptors to AN and get a hydraulic hose made locally if necessary.
I’m following along with this… lol
not really a huge difference with big tires...definitely better with 33s.
the sd and e series boxes are pretty good.
seen them in full size and buggy applications but not alot in rangers. more modded e than sd. i use the gm 2wd and e and over rail early ford....but the early fords are getting pricey....and stupid doodies are like rabbits....might be something worth looking at when i rework my rig.
give it a whirl
More research has led me to believe they offer more assist than the earlier boxes and are more robust in every way. Now to figure out all the bits and pieces to make it all work. I'll update this as I work through the hurdles.
Looking at the box I have tells me I have the late 08 box which has the weird triangular input shaft, vs the 36 spline shaft which is identical to the Ranger shaft. Not sure if i can find a shaft and change it, parts are kind of limited.
they are swappable to a point
get the stoopid duty shaft or the 07 spline input
Featured Ranger Based Vehicle
