302 Swap Questions
-Ghosty-
Greensboro, GA
2.3
I have a line on a 1997 V8 Explorer, and was curious if there were any reason not to use that engine/harness for my swap into my 95 ranger. Or if there would be major complications based on that either.
Also figured I'd ask if there were anything else I should make sure to get besides the accessories, harness, radiator, and of course the engine.
Read a lot of threads, but couldn't help but double check in case I forgot, or missed something along the way.
Thanks a lot for the help, as always!
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Born with a 3.0, looking for a donor V8
2WD / 4WD
2WD
Stock 2"
Stock
Doing things wrong, until I get it right.
-Ghosty-
Greensboro, GA
2.3
Haha. Guess I should have mentioned, I already have an explorer 8.8 installed.
Ranger850
4,691
Tallahassee Florida
2WD / 4WD
2WD
Stock 2"
Stock
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
Engine Type
2.9 V6
177 CID
2WD / 4WD
2WD
A legend to the old man, a hero to the child...
97 is OBDII.
95 is OBD1/EECIV.
Not sure what that entails for swapping. Plus wont a 97 exploder have PATS?
Also, if the 97 has the 4.0 SOHC (i think 97 was first year for it) you dont really want it anyways.
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
97 is OBDII.
95 is OBD1/EECIV.
Are you sure Rangers and Explorers didn't go to EEC-V in '95? I wouldn't swear to it, but that was my recollection.
A '97 will not have PATS.
If it's a '97 V8 Explorer as the OP said, it's unlikely to have a 4.0 V6 installed.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,833
SW Iowa
Engine Type
V8
5.0
Fullsizes hung on until after '97 because Ford knew there was big redesigns coming down the pipe.
I think most everything else switched in '95.
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
Engine Type
2.9 V6
177 CID
2WD / 4WD
2WD
Shit. You are correct on that fact. Talk about a brain fart.
Not totally correct. The 250HD and 350 kept EEC IV untill 97. The 1/2 ton and LD 250s had OBDII in 96. My 96 150 with a 300 was OBD II.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
Here is the break-down of EEC-IV vs OBDII:
The EPA said everything had to be OBDII by 1996 model year. This came out right as Ford redesigned the 3/4 ton and larger trucks, and they wouldn't be due for overhaul again until the 1998 model year.
Ford cut a deal with EPA. They would get their 1/2 tons over for 96. They would get cars and 1/4 tons over on their overhaul schedule (all of them coming over by 1995). In exchange they were allowed to keep the 3/4 ton trucks EEC-IV until the 98s came out.
So in the early 90s you can find all sorts of oddball stuff if you know where to look. I have seen 95 MY Rangers built in mid to late 94 with both the OBDII connection under the dash, and an EEC-IV diag port, listed at EEC Diag, under the hood, next to the ABS one.
I have also seen a 94 Thunderbird with the same arrangement, except the OBDII port was in the glove box where it belongs (per ASE the OBDII connection is no to be hidden, covered, in the way, or placed anywhere in the driver's foot well so that is findable, accessable, and does not pose a hazard while driving with a scan tool connected).
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,833
SW Iowa
Engine Type
V8
5.0
Ok, dad's '96 '250 is not OBD II, I figured the half tons would be the same... because they are pretty much the same. ;brownbag;
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
Engine Type
2.9 V6
177 CID
2WD / 4WD
2WD
My 97 HD 250 is EEC IV. I like it that way. OBD II is to picky.
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
Crazy my 95 is OBD II but is a late 95
That's correct for a Ranger (or basically anything Ford that isn't a full size).
rusty ol ranger
2.9 Mafia-Don
7,494
Michigan
Engine Type
2.9 V6
177 CID
2WD / 4WD
2WD
Im curious now about the one thing ford always bastarized....
The Econoline.
When did they all switch? Logic says they followed the Fseries, but is there possibly OBD II 351/460 econolines runnin around out there?
-Ghosty-
Greensboro, GA
2.3
Well I learned a lot about obdI and ObdII, MY 95 has the obdII port next to the hood release. So there should be no issue there.
So no other sugguestions on things I might need/want? If not I can't wait to get into it. The ole 4cylinder with nearly 600k miles is due for an upgrade. :yahoo:
Staff online
Members online
Shran
April Truck of The Month
