Barney and L’il Bit
Only reason I learned? Building a 1t 4wd cab & chassis search and rescue dually. I “need” 14 ply rated 7.50-16LT bias ply mudders. Damned things are speed limited to 63 or 68mph… Truck tops out at 72mph, 12k# gvwr, 22k# gcwr, 350 Vortec (carb conversion underway), NV4500 5spd (flimsy), Borg Warner 4470 transfer case (heavy), 4.10 gears and a 1200# all steel 7.5’x 9’ flatbed… Truly needs an SAS, 500 Caddy or 455 Buick swap. Not in the cards for a tired veteran turned corrections officer.
Reversing this undercarriage paint “scheme” for Barney. And both trucks will have creme colored rear axles since I have a can of Interlux top side in that color.
The dually has a black flatbed with bright yellow headache rack and side boards, black over silver cab/front clip, for now… Going with the same dark purple pearl on 4 trucks.
  • Barney and L’il Bit
Driver side. 1992 take off wheel, P225/70r14 Uniroyal Liberator A/T. 50k mile tread life my butt, I put close to 65k on them myself… Wish they were easier to find outside of PA, NY and CA.
Barney and L’il Bit
That “ Wobblin’ Goblin” has been carpet taped right there since I inherited the truck in 2011. Wish emblem tape stuck that well…
Barney and L’il Bit
Gonna take a lot of wire wheels… But, brushed aluminum with a good 2k clear will work. You watch, “Bitty By Tiny” (Shelby) will steal it for one of her red trucks. She’s like a crow, “Ooh, shiny”… 😂🤣
Already emailed Prothane, this was one of their kits. Never had poly bushings heat degrade before. Wear out? Yes.
Prothane/Energy Suspension (same website, both companies) is very confused. Have a listing for a body bushing kit, in black, ordered in 2017. Um, no… Spring/shackle bushings in red? Yes. Radius arm kit in red? Yes. I don’t order in black, too hard to see… Unless Lisa already bought them and squirreled them away. Now I’m confused… 👿
Looking to swap to these or similar. But $120 for plastic with a 6 month warranty?!?
I would prefer original Splash mirrors, but they are worse price wise. Truck does not have an inside rearview mirror. Not planning to add one when the windshield gets changed. CB is going big rig style between the visors. So I will need decent exterior set.
Barney and L’il Bit
You looked at the '06+ mirrors? Apparently they aren't too bad to swap to...
Familiar with the power version, Shelby’s ‘07 has those. They work great for her, but seem to have some serious dead zones the times I’ve borrowed it as a parts runner. I can’t adjust them up high enough, and they are only a couple years old. Maybe the manual version is better?
The stock ‘94 mirrors worked fine, just was wanting a some what more aerodynamic look.
Yeah, I have seen some people do it but haven't looked deep enough into it myself... yet, I've had the sliding rear window and rear popouts for like 3 years and haven't stopped long enough to do that either, let alone the explorer overhead console... man I need to get on some of that to free up space!
