wiring harness / steering coulumn
2drxploder
436
usa
ranger
347
lower
235 on 15s
so i pulled the motor harness and column from 98 expo today, need some help thinning down the harness for manual trans swap any good threads on this? my 99 ranger 4cyl has no pats so i pulled column as well, what have yall done with AT shifter and gaude display (PRND21)?
oh and white gauges, overlay or find a different cluster?
2drxploder
436
usa
ranger
347
lower
235 on 15s
Did I get the pats module?
2drxploder
436
usa
ranger
347
lower
235 on 15s
No. 1 vs no. 2 piston, as no.1 hole is scarred
Junglejoe
66
Columbia Missouri
6.0
I just took the pnd123 plaque out. If you're going to be running.a 5 speed, which is what Ive done....
I depinned all of the automatic wires, and then got rid of the entire bulk plug.
Only thing that goes under the truck on the passenger side is the front o2, and backup lights.
2drxploder
436
usa
ranger
347
lower
235 on 15s
Wow, I need to start studying some wiring, do you use a specific tool for depinning?
Junglejoe
66
Columbia Missouri
6.0
Just a cheap pick from harbor freight is all you need or you can use a paper clip ground down to a point. You do NOT want to be prying to hard on those plastic tabs on the main engine harness connector!!! Just simply slide the pick or paperclip between the wire lock and wire..pull it out of the connector.
You have to be able to reuse the red plastic locker so the rest of the wires stay in place. Its time consuming... but can be done easily.
Junglejoe
66
Columbia Missouri
6.0
I'll see if I cant get a little demonstration video on how it works...
