2.3L ('02-'11) will not idle
maverick9611
augusta georgia
ranger xlt
anybody know compression specs for the 2.3L?
pjtoledo
2,968
Toledo Ohio
Fords
3.0 2.3
this is the intake flapper control gizmo, 2002 2.3 manual on a stand.
there is an actuating rod that runs thru the intake, it's bushings wear out and rattle.
37815
pjtoledo
2,968
Toledo Ohio
Fords
3.0 2.3
I would be more concerned with the variance between cylinders than actual numbers.
as long as the oil consumption is good the rings are OK.
a vacuum gauge will tell you if a valve is leaking, reading will jump all over the scale.
maverick9611
augusta georgia
ranger xlt
cyn #1 240
cyn #2 185
cyn #3 200
cyn #4 205
put in new plugs, same issue/no change. moving on the fuel injectors/fuel pump
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Those sure are some odd pressure numbers.... either your guage is horrible or you need to be running 120 octane jet fuel.
maverick9611
augusta georgia
ranger xlt
found it! the plug kicked out on the intake
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
wonder what caused it to pop out like that.... I know nothing about the newer 2.3 engines so this had me baffled from the get go. Is it running good now?
maverick9611
augusta georgia
ranger xlt
running completely normal
maverick9611
augusta georgia
ranger xlt
i do not know why the plug pops out. their is a thread on somebody's popping out and replacing with a brass plug. i rtv'd mine back in
