Explosive
- Sep 14, 2009
- 0
- Michigan
- Ford
- Engine Size
- 2.9L
Who Makes The Better Lift? ~ Also A Question On Shocks
I've been slacking on my B2, wanted it done this month. But it's nowhere close.
Always planned to do the Skyjacker stage II 6" lift, extended arms, leafs ect. But I was browsing James Duff site and I see their 5.5" lift,
Here’s the deal. We’ve been working on our 5 1/2”-6” lifts for several years... but we hadn’t released them because we were unhappy using radius arm drop brackets. So, here they are— available only with our extended radius arms. We feel this is the BEST way to lift a TTB this much for the sake of safety, strength, handling and ground clearance. This means the lifts include:
•5-6” Progressive Rate Coil Springs*
•New Coil Tower Dual Shock mounts
•Rod Ended Extended Radius Arms
•HD Tranny Crossmember
•Extended Stainless Brake lines
•Drop pitman arm (fits PS only)
•Axle pivot drop brackets
•4 front shocks, 2 rear shocks, 6 shock boots
•Urethane coil pads, leveling spacer
•U-bolt kit
•Leaf Blocks, if applicable
•Complete Replacement Leaf Spring Packs
•Spring Eye Bushings
*Lift heights will vary by vehicle configuration.
PART# 5050-3 - Stage 3 Suspension, Bronco II 4WD, 5-5.5 $1829
So who makes the better lift kit ? I'm finally ready to start moving on my B2, first up is the 4.0L swap (motor sitting on stand in garage) Then the lift. Just trying to find the best lift.
•U-bolt kit
