Where is an entrance on my firewall!?
Ramonjportilla
1996 ranger, I just put new headlights in and I need to find where I can run my projector lights to a switch through the firewall.
8,374
Emergency brake cable usually has enough room.
Might even have the old speedo cable hole, 1994 was last year of the speedometer cable.
You should use a relay in the engine bay so you only need one small wire to the switch.
12volts(5amp fuse)------Relay-----(firewall)--------switch---Ground(in cab)
12volt Relay activation is less than 1 amp so you can add it to an already fused circuit, a key on or 24/7 circuit
Ramonjportilla
My fog lights came with a fuse on the wiring before the switch. Would it be a bad idea to run them on my running lights? I don't want to mess any of my existing electrical system up. So I figured I'd just use the switch.
Ramonjportilla
Also the fog lights are in the headlights. They are projector fog lights.
