Wheels and tires 15x8
buzz88
Southeast PA
Bronco II
2.9L
Thinking of swapping out my 87 B2 the 15x7 explorer wheels and 235 75 15 tires for 30x9.5 on 15x8 wheels, or maybe 16x8, any suggestions for 8 inch wide wheels and offset? I like the look of what I have but would like a wider stance. Thanks
Junk Collector
Truck of Month
4,806
Rapid City SD
I have Mickey Thompson 15x8's and BFG 30x9.50-15 tires on my Explorer. I believe they have 3.6" backspacing, -22mm offset. Definitely a wider stance, if you had these on your truck, they would rub in certain places when turning (I had them on a 1st gen Ranger too.)
Maybe these pics will give you some idea what you're getting into and you can choose a wheel design of your liking:
No lift
After 1.5" lift in the front
31" Duratracs on the same wheels
Those Duratracs on my other Explorer:
buzz88
Southeast PA
Bronco II
2.9L
Thanks- nice 1st gen explorers especially the sport. I ran 30x10.5s which are rare on 15x8 on my old 89 B2 and that was a great setup no rubbing somehow stock
gaz
659
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
buzz88,
On my 87 BII, I am currently planning to mount 235/75r15 Cooper Discoverer A/T's on 15" x 8" black steelies (pulled from a late 80's Jeep) to dodge the cost of regearing for the next few years. If you have 3:73's, that is the perfect tire size.
I like the idea of using stock Explorer wheels, the set you have look nice; pretty sure they can handle 30x9.5's, though 15x8's are hard to knock! I used 15x8's when I 1st went to 30.5x9.5 without fender trimming, no lift, only the slightest rub on the outside with steering cranked to the stop.
buzz88
Southeast PA
Bronco II
2.9L
Yep the explorer wheels I have are nice just wish they gave the wider stance. Thus the thinking on the 8 inch wide wheels - always liked the wider stance and felt more stable, even if it wasn’t!
