- Oct 20, 2021
- 4
- Sechelt British Colombia
- Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
- Tire Size
- 285/75 r 16
Installed 285/75/16 on the stock 16X7 rims of my 2011 Ranger.
They rub a bit on the sway (stabilizer) bar. I would like to put some wheel spacers on to give it a wider stance and eliminate the chafing.
I can find https://nsor.com/trail-gear-tg140002-2-kit.html or
The difference is 5x4.5 and the other is 5x5.5 ? does that represent distance between lugs?
Trail Gear Wheel Spacer Kit, 1.50
Jeep Aluminum Wheel Spacers These bolt-on wheel spacers are designed to give you a little more width without changing out your axle for a wider one. 3/4ᅠ Features safety graded studs and matching nuts for proper fit. Spacers are 1.25" and 1.5&qu
nsor.com
