Wheel bearing question
98 ranger xlt
California
Can i use new wheel bearings on old races if i pack them good?
nitrofan1
Man without a Ranger
MTOTM Winner
19
Chattanooga, Tennessee
Subaru
EJ251
Completely clean them & inspect. I personally wouldn't do it but if there are no blue spots or cracks & scarring it should be ok.
flyingbrick
Winnipeg, MB, CA
There cheap, in fact most bearing come with them, and they're easy to replace, just do it.
98 ranger xlt
California
Well, i had the bearings packed but there is a humm, like a big mud tire going down the road, you can hear it more when stopping. Any ideas.
98 ranger xlt
California
Bump, anybody?
cocoasranger
5
south central Pa.
+1 It's a crap shoot to use old races with new bearings. Sometimes it works ok, but sometimes:icon_thumby: you roll snake eyes which is what it sounds like you did.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
The hummm is not a good sign on a recently worked front end...don't the bearings come with new races? I know the rotors do...and putting new bearings to me included new rotors...so I can't remember where they came from...
I'd redo it with the new races...and also make sure the nut is tightened properly...if it is not you could end up losing the front wheel...
fixizin
FoMoCo is forcing me to buy a 'yota
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
Are you sure your vendor didn't pull the races out of your bearing set, and try to "jack" you by selling them to you separately? BASITIGES IF they DID!
I'm seeing a film loop of a Molotov cocktail, crashing through their window... my bad. :shok:
98 ranger xlt
California
I did not get new ones i had the old ones packed.
falcon57
For what it's worth; I've driven out the old races with a brass drift and after the drift broke, I used whatever I can find to knock'em out and install. They've held up fine!
FordMan016
thunder bay
big bad 3.0L
when going new usually a good idea to go all the way with most things.
cocoasranger
5
south central Pa.
So if I read correctly, you just had the old bearings packed and no new parts were installed. In that case if there was no hum prior to repacking, it's likely that the repacked bearings have the wrong preload on them (ie., too tight or too loose).
You might want to have their adjustment rechecked.:icon_cheers:
