Whats in my Hybrid 35
clark89
Ottawa
2.3L
So i recently bought a 94 ranger and to my disappointment I found out after i got it that it had a hybrid 35.:bawling: So I was wondering if anyone knew what gear ratio they come with. I was told it was 3.73, but then i was told it could also be 4.10. I know i can check the stamp on it but its gone, so I cant do that. Also I have read that Dana28 gears wont fit and neither will Dana35 gears. Is this true:icon_confused:, and if so where can i get some gears that will work. I am also wondering if it would hold up with 33s or 35s.
Any info anyone could give me would be great.:icon_thumby:
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Your best bet is to swap it to a "real" D35. Fortunately this is pretty easy, all you have to do is swap the hybrid chunk out for an actual D35 chunk (be sure you also have the two axle shafts that enter into the chunk, the D35's have a much larger spline on them).
The D28/35 axle I wouldn't trust with more than 31" tires on it honestly.
For your gear ratio, check the axle code that's on the sticker on your driverside door. Then reference it here:
http://www.therangerstation.com/tech_library/Axles.html
Additionally, you can check the tag on your rear axle. The front would have to match.
Hope that helps :icon_thumby:
Downey
Muncy, PA
what motor is in your 94?
clark89
Ottawa
2.3L
I have a 2.3L, 5spd.
chrisparks201
ottawa
2.9 v6
i personally think you should get rid of the gay decals on the side before you do anything...
clark89
Ottawa
2.3L
God I hate you.
86 slo-vo
02/2011 OTOTM Winner
36
owensboro, KY
just switch the hog head for a D35...dont waste money on a hybrid
clark89
Ottawa
2.3L
Well i found out today that i have 4.10 gears so i think im just goin to try it with 33s and see how it goes, and WHEN it breaks ill swap it out.
