Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
That’s fine. But you should still add diagonal braces or gussets to that cross member you built. Otherwise, it will break from side- loading.I will add a sway bar soon
A sway bar won’t add any strength to a frame... You need a crossmember that keeps the frame rails from bowing in and out. The one you have won’t do that, but it can be changed to work.I will add a sway bar soon
I am not finished with the top yet and I will be adding a sway bar soon. But thanks for potting that out to me.
you should start a build thread so others can follow your progress. The 4.6 in a Ranger is still a pretty rare bird. especially one that is well documented. There are a few here with 4.6 Rangers but the build threads are less than informative. I am in the process of starting a 5.0 swap into mine, but thought about the 4.6 because there are at least a 100 in the JY at any given time while the Expo/Mounty 5.0's are drying up around here.I don't have the motor back togeather yet
They make it look so easy. I wonder where the steering column shaft is supposed to fit.
