kimcrwbr1
- Dec 6, 2009
- 46
- maplevalley WA
- ford
- Engine Size
- 2.8l
A simple test for the exhaust is to hold your hand over the tailpipe and have someone goose it if the gasses coming out dont increase evenly with the engine rpm you probably have a restriction most shops will tell you what it needs. Are you resetting the computer every time you clean/change a sensor. Disconnect the battery for 1/2 hour to reset the comp then run it at medium speeds for 20 mins cycling the A/C if you have it. The computer corrects for worn parts but wont go backwards always disconnect the battery when you change a sensor and let the computer relearn operating values.
