What the heck is up with my trucks trailer lighting?
bluebombersfan
I hooked up my first trailer to this truck a few weeks ago. Did a light test and left blinker wasn't working on my old trailer. Big deal I thought it was an old trailer needed new lights and wiring anyway. Upgraded all the lights and wiring and same problem.
I tracked the problem to my truck. But it's not that simple. Here is whats going on. Left light and brake light don't work. Then I put my night lights on then left light is very bright. left brake light then works but left signal light will still not work.
Please someone make my day a tell me there is a quick fix to this because this is the most screwed up thing. This makes no sense to me.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Take the bulb out and see if the socket is melted/corroded. Also, pull the harness apart that is behind the rear bumper and check for corrosion.
Sent from my Quad Core Acer A210
bluebombersfan
Like mentioned lights are new. its coming from my truck all screwed up. I already put on a new harness myself. I checked many times I lined up all the wires correctly on the new harness.
I hooked up a single light to each wire I could not get a flashing left signal light from any wire. Something is very off and very strange about this. I am almost wondering if this might be some kind of wiring screw up from the factory because I have never experienced such strange behaviour like this for a simple 4 wire trailer wiring.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
I'm not talking about the bulb. I am talking about the socket the bulb goes in to. And by replacing the wiring, I assumed you meant you rewired and replaced the trailer stuff, seeing as how all of that is in your paragraph about the trailer. Did I misunderstand? What exactly is new then (on the truck)? Did you buy a new harness, junkyard harness, etc.?
Sent from the can
8,374
If it makes no sense then it's probably a ground problem, lol.
This is a good resource for trailer wiring
http://www.therangerstation.com/tech_library/TrailerLights.html
Brighter light can mean that light is being used as a ground by something else or if its a double filament bulb then the wrong filament is coming on or both are coming on.
The bad ground could be, and most likely is, in the truck
fyre82
Firefighter
6
Lake Almanor, Ca.
2.9/4.0
9" on the 2000, 6" on the '88
265/75/16, 31x10.50x15
The memories of a man in his old age are the deeds of a man in his prime
+1 on the ground issue.
I completely pulled the wiring out of my first trailer because it was wonky, but when I hooked it into the truck harness it worked fine.
I fixed grounds between the truck and trailer and have great function and bright lights.
What I did was add a ground wire to the hookup. One end grounded to the truck, the other to the trailer.
Rich
